Recommendations...
{NcsO}ReichstaG
"intel pent 4
internal cache: 8 kb first-level
1.2 cache integrated 256-kb at full microprocessor speed
system chip set: Intel 850
Data Bus width: 64 bits
address bus width: 32 bits
DMA channels eight
system bios chip 4mb
system clock 100;400 Mhz data rate
Expansion Bus
bus types PCI and AGP
Bus speed PCI:33 Mhz; AGP: 66Mhz
AGP connector one
AGP connector size 172 pins
AGP connector data width (maximum) 32 bits
AGP bus protocols: 4x/2x modes at 1.5 V
PCI connectors five
Pci connector size 120 pins
PCI connector width (max) 32 bits
Memory
Architecture RDRAM
RIMM sockets four
RIMM capacities 64-128-256-and 512MB RDRAM
Standard RAM 128 MB (minimum)
Maximum Ram 2 GB
Bios Address F8000h
Power
DC Power Supply:
Wattage 250W
Heat dissipation 913 BTU's (fully loaded computer without monitor
Voltage (auto-sensing) 90-135v at 60hz
180-265 V at 50hz
Additional info;
the computer has up to five 33-Mhz 32-bit PCI cards
one 32-bit AGP card. The slot supports AGP 4x or 2x modes operating at 1.5-V.
I was told at one point that to use a flat panel monitor I needed a AGP 4x slot compatible.
It was recommended that I buy a 64mb NVIDIA GeForce 3 TI 500 and it has a DVI interface
to go with a variety of flat panel monitors that also have the dvi interface.. "
So, which videocard would you guys reccomend to buy for someone who 1) doesn't want to spend alot of money. 2) Wants to use a flat-panal monitor 3) Doesn't play games alot or almost at all. And the games the person plays are not demanding. 4) Watches DVDs on teh compuer.
So which videocard do you reccomend?
Are you putting the card on the computer in the way too detailed description or the one in your signature? If you don't care about games get a 9200se or something cheap from ATI with DVI output. ATI's have good 2d image quality.
I am putting the card into the "way too detailed" description computer, not my own. Would you reccomend any of the GeForce TI (something, something) cards? Are they cheaper than the 9200 SE?
The Geforce 3 Ti's were great cards back in the day. I don't even know where you could find one. I know that the ATI's have great 2d because I owned one. The older Geforces did as well. Whatever has DVI is what you need for the flat screen.
What about the GeForce MX 4000 ? It has DVI and costs about $40. What do you think of it?
Its cheap, has excellent 2d image quality and you could play a game on it if you wanted to and didnt care about high resolution 3d. Did you even read the reviews for the product? IF you had you'd notice the kudos it got for its image quality, which is what the question pertained to.
