Recommend me a Photoshop machine please...
Lyquist
I am going to be building a machine for a customer for Photoshop and I've never done this before. His budget is no more than $1,200. He does not need a monitor or keyboard or mouse. He wants to stick with Intel Core 2 Duo. Please give me your feedback about this. Thanks in advance.
Intel Core 2 Duo E6300 w/ Cooler
Gigabyte 965 DS3
2GB Corsair DDR2-667 Value Select
250GB Seagate Hard Drive (7200 RPM)
DVD Burner
Floppy Drive
Seasonic 500W
Case (Your choice)
Now the kicker... is this customer going to play ANY games at all? If not, he can stick to a version of the DS3 with onboard video, or get a low performance card, like the 7300. If he games, then talk to him about a 7600GT or something ish like that.
Cheers. I couldn't get pricing, as I don't know where you're from, so prices will vary. For example, in Canada, 1200 is not so much.
If he's a Professional using Photoshop, then I'd recommend a 64bit operating system and 4gig of ram. Also a 74g raptor scratch disk to go along with a storage disk (whatever you can get for a $100). Otherwise, the system listed above is pretty good.
If a non-pro then what the guy above said :D
How about a compromise... quality board, CPU power, avg ram, fast hdd, no gaming... oh, did that $1200 include software/os? hehe... if not (and assuming you're in the US):
$313 - Intel Core 2 Duo E6600 Conroe 2.4GHz
$123 - Gigabyte GA-965P-DS3 Socket T (LGA 775) Intel P965 Express
$169 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
$160 - Wd Raptor WD740ADFD 74GB 10,000RPM SATA150 16mb Cache ($20MIR)
$100 - Corsair CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W
$30 - Cooler Master RC-534-KWN1 Black Centurion Steel Mid Tower ATX Case w/ Side Window
$75 - Seagate Barracuda 7200.10 ST3250620AS 250GB 7200RPM SATA300 16MB Cache
$40 - Freetech PX6200TD-128M GeForce 6200 128MB ($10MIR)
$32 - Lite-On 16X DVD±R DVD Burner Black SATA SH-16A7S-05
$1042 + tax and shipping - $30MIRs
Need a better vidcard? You'll have to sacrifice the fast raptor and choose:
$110 - eVGA 256-P2-N615 Geforce 7600GT 256MB ($10MIR)
$157 - MSI RX1950PRO-TD256E Radeon X1950PRO 256MB
If you did need an OS, drop the CPU down to the E6400 instead.
He will do no gaming at all. He just talks about wanting to use large resolution photos. He will also be buying a large format printer as well. I don't really intergrated video to be honest...but is the Gigabyte DS3 with intergrated video enough to run photoshop??? I don't know at all, as I don't know photoshop at all. Thanks in advance.
Would two gigs of RAM be enough with 32 bit windows??? I'm already straining his budget as it is. He wants something for $1,000....which after I make some money will be impossible unless I want to make less than $100 and it's just not worth it to me at that point. I've just always heard that Photoshop likes dual core and lots of RAM. I'm really lost here. I will most likely be ordering from Newegg as well.
Yes, 2GB will be enough, with his budget. Photoshop is all 2D, so yes, the G965 Express chipset on the GA-965G-DS3 would be fine for photoshop. However, that only shaves off $40 from the total. If you want to make some money, either drop the raptor down to the 36GB model, or drop it completely. This would have the least performance effect while freeing up some cash. If you want to shave more off, like I said, go for the E6400 instead.
Here's some reading material for you.
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2903
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2802
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2795
http://dailytech.com/article.aspx?newsid=5414
I need some more suggestions. Would a dual core AMD work just as well??
For a cheap solution, than AMD is your best bet. But for a fast and best bang for the buck solution, go with an Intel. With a budget of $1000, it's better to go with a Core 2 Duo rig.
Enginurd's already posted a workable solution to whatever dilemma you're having. Go with Enginurd's build except drop the E6600 to a E6400, go with the GA-965G-DS3 motherboard with onboard video, ditch the raptor and the Seagate 250GB hard drive and go with this hard drive:
Seagate Barracuda 7200.10 320GB 7200RPM SATA 3.0Gb/s - $89.99
Still pretty fast and plenty of storage for those large photoshop files he'll have. Now you have a bit of extra cash for yourself.
Oh will you need an OS?
Depends what type of photoshop work
alot of filter work = cpu speed
just editing alot of pics= more ram and fast hard drives - I/O
i would def say a seagate 7200.10 drive for storage and a raptor for the main drive and MIN 2g of good ram, not some value ram.
i would grab some $100 Intel board since i assume no overclocking is needed so the stability will be nice,
maybe even consider a raid 1 set up for storage using a board with intel ICH7.
