Recommend me a good mobo..
EarlMcFish
I switched to macintosh and have been out of the pc world for a while. I'm looking for a good motherboard to build a new gaming rig.....AMD and Intel...I haven't decided yet. Looking to spend around $150. Links if possible..Any good SLi boards for Intel yet?
I think going to have more than $150 or was that misprint that might only buy you a motherboard.
I'm just looking for a good mobo to buy that costs no more than $150. Both AMD and Intel...just to see what my options are.
If you're buying now, I'd not get an Intel. I'd get a dual core AMD X2 or Opteron and a decent OCing SLI board. The classic is the Asus A8N-SLI, but others are just as good.
I would have to agree that amd is the way to go.the asus a8n sli is a fine board for the $100.00 or so it costs.the biostar tforce sli board is also a good board.the dual core 3800 x2 or one of the opterons are good o/clockers.you really dont need to spend 150 on a motherboard,there are many great boards for around the 100 dollar mark with sli.the ultra boards are a little cheaper if your not going sli.you get about the same performance from 1 of the altest video cards out vs going with 2.too expensive for my tastes for the performance difference.imo sli and cf are a fad that will disappear when dual gpu's hit the market.if cash is no problem and you want sli then go for it.if your on a budget then 1 top of the line video card on a good ultra motherboard is so close to sli its hard to say if the difference is worth the extra cost of a 2nd 400 dollar video card.just do some reading on this and youll see.........
What's no good about Intel right now?
I'm run this board right now it isn't a SLI but this is really good board been running for about 8 months running all the time 24hrs a day 7 days a week. I don't know how much the price is. great board dual core
AW8-MAX 3rd eye II P4 D 830 Smithfield
Corsair XMS2 (2x512mb) PC2 6400
Leadtek PX6600GT TDH 256Mb
