I have a couple of last gen Samsung TVs but the pieces of crap love to corrupt data on youtube or Netflix App and it's impossible to clear the cache or simply restart the apps because Samsung is more invasive everyday, you can't even reset/restart the goddamn TV the only way to remove/reinstall/clean apps and cache is to do a factory reset for the TV and it deletes everything and it's a pain to download and configure everything again from the remote.
So... I want to get an android box instead of using the smart features, however nVidia Shield and all decent boxes are $150-$250 which I find crazy.
Do you guys know of a decent Android TV box that works nice ? both TVs are 4k so if they support it that would be nice but I can leave with 1080p
Thanks guise.
Thanks guise.
