Recommend cheap basic iTX
tuberc
Im just planning a cheap pc for internet use, its mostly going to be used for skype. Can anyone point me in the direction of an iTX board thats under 100US? The cheaper the better, I will pick the CPU after selecting the board. I need sata and onboard sound and video.
The case is going to be custom and The PSU will be low voltage, maybe something like a picoPSU or SFX.
Any help much appreciated
That's a pretty good board. There is an Intel version of that, but it's $145 or so and OOS.
The nvidia 8200 chip will do whatever you need it for.. plus the processor and ram for that board are about as cheap as you'll find.
IIRC, the 8200/8300 is the AMD equivalent of the 9300/9400 Intel.
Pretty much. However, the AMD side is cheaper to build and will give very similar results depending what you use it for. But, we are talking about mini-ITX sized boards here.
yeah, I agree. You're normally not building a mITX setup with a high wattage quad core for lots of encoding work :).
thanks for the link, i was looking at an intel atom board the D945GCLF2. It is going for 115 with 2gig on ebay. This gets rid of the need to buy seperate components. The atom 330 should have plenty power for what I want it to do.
Do alll the picoPSUs come with the power brick?
I had to order a power brick separate. I purchased from here and just made sure to add the appropriate power brick to my order.
