Recommend budget Freesync2 GPU
Catboxer
Hey guys, I need some quick thoughts on which GPU to choose to drive a freesync2 display. This is for my father (non-gamer) who recently bought aultrawide LG 49" with 144hz/Freesync2. He's currently using the onboard video and only driving it at 60hz. I built this system a number of years ago, I think it has a 450/500w power supply. No need for a 2080TI, but I know 20 series Nvidias now support freesync but I'm not up to speed on AMD's current offerings. Looking for some ideas, cheaper the better. Thanks!
Is there a specific issue that makes you think it requires freesync?
Just asking as you stated he doesn't game.
AMD RX 560 99$ @Amazon 75W, no additional PCI-E power connection required. so it may have your name on it.
I personally think it's worth going to 144hz just for the desktop experience (smooth mouse/window movements). Seems like a waste of a good monitor.
If you're dad is not gaming, that RX 560 would be fine.
I was using an RX 460 (very similar) for a bit on an HTPC and I was happy with it for general PC usage.
It could even game with some older titles like Half-Life 2 or Left4Dead, but it was a stretch for anything newer.
Should be a fine choice. Just note that FreeSync is mainly for playing games, I don't think it does anything on the desktop.
Are you set on buying new? There are a lot of RX580's floating around for sub-$120 that would give you a lot of bang for the buck.
