In a nutshell, this system is an upgrade from my 3+ year old previous computer (see sig). In theory, I'm building it just to tie me over until DX10 and the respective new hardware tech that will follow. I'm a gamer so I'd like it to be pretty solid, but I'm by no means trying to buy the best of the best current tech for the time being.
With that said, I'm having a terrible time chosing a motherboard to backbone my new system. I was first attracted to the P5B but then was warned of it's many problems. I then continued to look into Intel 965 and 975 boards but then found many similar reviews. Then I looked into similar Abit and Asus 965 boards and found the same stuff. I finally checked out the Gigabyte DS3 and, you guessed it, found similar negative reviews.
So what's one to do? How am I supposed to make a good purchase when so many of the available boards have come under scrutiny? Sure, one or two people might reply praising one or the other boards, but what about the *numerous* negative claims found on sites like NewEgg?
That said, can I maybe get some recommendations of one of these boards, with my system specifically in mind? Rather than giving blind "I recommend x board," can I see some reasons why, maybe being that you run it on the same prospective processor as me, for example?
Thanks for any help guys.
Fwiw: I haven't done much OC'ing in the past.
Question: Will one of these motherboards carry me into DX10 (IE does DX10 only require a new video card)?
Prospective system:
E6400 2.12ghz processor
2x 1g DDR2-667 memory
7600gt video
SATA hdd
USB 2.0 and FW-800 would rock (especially if able to be routed to the front of the comp)
Prospective system:
7600gt video
SATA hdd
