Recommed a case
c2rex
I am looking to rehouse an older system I've had heat issues with. The power supply has been replaced recently. This system is on its 3rd video card.
I would like to go with a mid tower, and I have a new power supply. I would like the power supply to be bottom mounted. I would like the ability to install no smaller than 120mm fans (at least 2). Not concerned with color, lighting, front panels, fan controllers, or water cooling. Doesn't have to be fancy, not loyal to any particular brand. Would like to keep price under about $80 if possible, but I don't want to be replacing switches in 6 months.
With the info I've listed which cases should I be considering?
