rebuilding Dell Dimension 8400 will it work?
Lupyne
My 8400 has problems with spontaneous shutdowns (quite common from what I read on the dell forums) so I'm replacing the motherboard and power supply with non-dell parts in an attempt to escape from pure hell I mean pure dell..
What I have-
Intel® Pentium® 4 Processor 530 3 GHz 800 FSB 1MB L2 Cache LGA 775
http://processorfinder.intel.com/details.aspx?sSpec=SL7J6
two 512MB samsung DDR2 533 DIMMs
sound blaster audigy 2
V.92 data/fax modem
Radeon X300
and the tv tuner that comes along with (has it's own PCI slot)
two 160GB, SATA, seagate-alpine (0 RAID array)
DVD-RW combo drive
and a floppy drive!
what I think I'm gonna buy-
Power Up Black 302 ATX Mid-Tower Case (so cheap and nice to mod someday maybe?)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2078846&sku=TC3J-4510
XCLIO GOODPOWER 500W ATX 500W Power Supply
http://www.newegg.com/Product/Product.asp?item=N82E16817189005
Foxconn 925XE7AA-8EKRS2 Socket T (LGA 775) Intel 925XE ATX Intel Motherboard - Retail
http://www.foxconnchannel.com/Product/motherboard_detail.aspx?id=en-us0000077
Is all this going to work together? anything better/cheaper out there? (remember I'm poor and dumb dell took all my money :( )
Dont expect to mod it easily. It'll take some research and work to connect the motherboard to the front panel, and having the back of the mobo allign right.
If you buy an ATX case and ATX motherboard, the rest of the parts should fit in a rebuilt computer with no problems. I'd look for a more modern mobo...that thing is ancient. One that supports dual core at least...946/965/975 board preferable.
oh ok I understand, thank you
I found this one:
http://www.gigabyte.com.tw/Products...rboard&ProductID=2314&ProductName=GA-965P-DS3
but it costs twice as much as the foxconn, does 965 really have that much better performance/reliability than 925? it'd be nice to be able to upgrade someday but for now my P4 is working fine and I'm thinking any motherboard will work better than the one from d(h)ell, also thinking if I get an older motherboard now, I can get one of the now-newer ones in a couple years too for the same price as a newer one now (no need to stay on the cutting edge when I play mostly old games)
If you want to do a rebuild of a Dell you have to turn your head around and look at moving out of the Dell box, reusing the salvageable parts in a "new" build and selling the Dell parts on Ebay. Dell is very proprietary and, as said above, rebuilding inside a Dell shell is not worth the trouble. The new mobo most likely will not fit the Dell case and you'll need to reload XP regardless.
What I suggest is you get yourself a nice mobo, new case, quality PSU, and an aftermarket HSF (Dell HSF's don't work outsude Dell). Then pull the CPU, HDD, RAM and vid card and install them on your new mobo, reinstall XP (yes, you can use the Dell XP CD as long as it is a full XP version and not a repair CD but you will be prompted to contact MS and answer a couple questions) and you will be amazed at the performance boost you get. You'll also be able to overclock now :D Sell the mobo, case and PSU on ebay. The PSU and mobo command amazingly high prices for what they are.
I did the above with my wife's old Dell and couldn't be happier. Of course she had a nice P4 Northwood 2.6GHZ CPU in there that is now running at 3.12GHZ (any faster would require I turn up the Zalman and she prefers quiet over performance) but I saved a few bucks as compared to a new build, get more use out of a nice CPU and made enough money from the reselling crap Dell parts to cover the PSU, HSF and a bigger HDD ( I had an old case and RAM) costs.
I found this one:
Personally, I have the DS3 board and it works OK. The draw for that board is that it is Conroe compatible if you decide to swap out your CPU in the future. It is the most flexible board you can get out of the 925/945/965 choice.
