The computer boots, beeps, then I get the message:
Press <Shift-tab> key to display network boot option.
Press <Home> to boot from local drive.
If neither is selected, it goes to the windows safe mode options.
If safe mode is selected, it loads a bunch of standard windows drivers, files, etc and then I get the message: "Press esc to cancel loading sptd.sys"
No matter what option is selected in ANY step, it eventually loads the windows splash screen and then I get a millisecond blue screen and it reboots.
In cmos, it doesn't detect my Primary or Secondary IDE. It does list the Maxtor harddrive in the boot sequence though. Won't boot from dvd but the dvd gets power.
Memtest is ok - brand new memory. Motherboard is brand new. Windows XP.
Since it's not detecting either IDE should I suspect harddrive failure? What else should I be looking at?
