Reasonable CPU/Mobo Combo?
chitzu
So, my friend's motherboard just crapped out (so it seems) -- and interestingly enough it seems as though mine has as well. We were still using NForce2 boards (Abit NF7-s and MSI K7N2D) and both assumed it was the video card that failed, but after testing, we found that the video cards and monitor work fine, but nothing shows on the monitor thus realizing it's probably a motherboard issue.
So now, we need to make a decision. Do we upgrade everything? Since after doing a little searching, it seems as though we'll need DDR2 RAM, PCI-E Video Card, and obviously a new motherboard and processor.
Is there any good motherboard/CPU combos available that will still use the normal DDR? Or is that completely out of date? I honestly don't know because I've been out of the computer game for such a long time.
Any help is appreciated. We're both looking for a decent system at a REASONABLE price, nothing crazy here, maybe a few hundred dollars total.
Thanks in advance,
-Jon
forget ddr. ddr3 has been available for a few months now, tho still expensive and not popular yet. get a ddr2 system. probably stay with amd. you can can a decent cpu and mainboard for around $150, like the combo on the bottom left of this page
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138061
you can get 2gb of decent ddr2 for $63 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
you can also go with an intel c2d system like a e4400 and some cheap g33 or p35 board for around $225. you would get about 25% more performance this way. check the third combo down on this page. this is probably the way to go if you have the extra cash.
http://www.newegg.com/Product/Produ...ubCategory=280&SortField=0&PageSize=10&page=1
as far as mid range vid cards go, i am not familiar with what is around right now, but i am sure you can get something decent for $100 or so. you didnt mention what you were going to use this for, or if you were going to overclock. then you would need some better cooling, possibly some better ram.
200 dollars for a new mobo,ram, CPU and GFX card = mission impossible for me unless you settle with a low low budget vidcard it might be barely doable.... and you will not enjoy the power of yoru CPU and co in the gfx department...
Only thing to go for is Ebay or buy froma friend that's gonna upgrade himself...
I know the old AMD socket 939 mobo's a la AV8 DLX from Asus used DDR and AGP but I don't see the point in investing in old hardware as the risk is very high something breaks and then you wasted just extra cash...
go as suggested above and try to go 300-350 dollar region, also taking into account a new PSU to power your brand new rigs as only thing you can recover is the case, Hd's and optical drives, yet also take into account most Intel mobo's only support 2 ide Drives now so if you have 2 or more Hd's , optical drives you will need to go AMD AM2
Thanks for all of your responses. I haven't had internet for the past few days, and I won't again for a few more, so I apologize for not replying. However, I would like to go the DDR2/PCI-E route, if my friend is able to send back his DDR/AGP to newegg. That way we'd be future-proofing ourselves a little bit. I would hate to waste money on old hardware when we would be able to get something newer for a reasonable price.
Also, if any new deals come up soon (this week - Sept. 1) please let me know in this thread.
Thanks again for they help,
-Jon
Just to let you know, you can still use your old AGP and DDR ram, if you're still interested. The AsRock 4CoreDual-VSTA or 4CoreDual-SATA2 supports both AGP and PCI-E, as well as DDR and DDR2. AT did some reviews on that board:
http://www.anandtech.com/showdoc.aspx?i=3024
http://www.anandtech.com/mb/showdoc.aspx?i=2810
http://www.anandtech.com/showdoc.aspx?i=2813
http://www.anandtech.com/showdoc.aspx?i=2814
Summary: The board is a good, budget stopgap solution for people who want to get more life out of their DDR and AGP stuff. DDR400 is still fine for today's applications, and only high end NVIDIA graphics cards will be affected by the 4x speed of the 16x sized pci-e slot, but not by much (only 10% performance hit).
Though, if you do upgrade to DDR2 and PCI-E, whats your new budget?
I am in the same situation. This looks like exactly what I need since my motherboard died a few months ago and the the only 754 motherboards you can find now are these super cheap VIA POS boards. This board is definitely a POS. Maybe it is a defect but I think it is probably too late to get an RMA. With this and a cheap Core 2, I can be back in business at well under $200. Wonder if this would increase my FPS too since the processor should be quite a bit faster.
heres the stuff I just bought.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220144 - $67
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186114 - $68
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103774 - $66
totals $201 plus S&H for cpu, ram, and mobo, and you could opt for a 3600+ for a few bucks less, some cheaper ram, and a cheaper mobo. id expect you could save $40 or so, so lets say u pay $160.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814122024
add that for $95 after rebate, your looking at a final price of around $250. not sure what kind of gaming you do, so gpu is up to you.
