RealBench 2.5x errors, 2.44 fine
Meeho
Anyone else experienced issues with Asus RealBench after version 2.44? I get processing errors and Time=0 in benchmark and stress test errors out indicating the 7z portion. It happens on two different configurations.
2.44 runs fine as does everything else.
Didn't they add AVX in the later versions? Your setup might not be AVX stable?
That when happens when you skimp on proper testing :D
Jokes aside. I dont think avx addition would have a direct connection with 7-z as 7-z is strongly integer based (lossless compression is not that optimal to run on Floats)
If real bench did add avx is was much neede for stabilty testing. real bench failed to impress me when i tested 20+ differet CPU stress programs.
They are Sandy Bridge configurations so new AVX isn't an issue (and I think it's not used for image processing anyway) and fail at stock too. The bench tests run fine, it's when they close to move to the next part that it errors out.
i didnt get to test it yesteday but i will test asus relbeanch to night
Reactions: Meeho
