Rats! Did I screw up again?
ih8spam
I purchased a PC4-1025BK last week, and I'm running my tubing to my different water blocks.
I noticed that I may have made another mis-steak.
It looks like my D-Tek Fuzion has 1/2" hose barbs, and the Koolance system is using 3/8" tubing.
Can I use some 3/8" hose barbs that came with my no-longer-needed Swiftec reservoir on the D-Tek Fuzion CPU block?
Or, can I stretch the 3/8" tubing to fit on the 1/2" barbs without causing other problems?
I can put 3/8" barbs on my GPU blocks (or, use 1/4" barbs and run the GPU blocks in parallel with the Koolance converters).
IH8Spam
"Or, can I stretch the 3/8" tubing to fit on the 1/2" barbs without causing other problems?"
This is your easiest and best bet. Boil some tap water and dip the ends of the tubing in, then quickly wrestle it on the 1/2" barbs of the dtek.
In order to swap barbs you need to know the thread type. I believe dtek is G1/4. I have no idea what swiftech uses. but if someone else chimes in and says they're G1/4 too then you can swap em. i think you may have miswored that though, you say you want to swap 1/2 barbs on the dtek to 1/2 barbs from the swiftech? i assume thats a typo.
Ooops! You are correct! I have changed my description above to match the real situation.
I guess I had a typo during my panic ...:D
Ok, looking at petrastechshop tubing and fittings page, it looks like swiftech is G1/4 too. So yes you can swap the the swiftech barbs onto the d-tek barbs! hurray :)
this how your barbs look? here I know the size is different but petras dont have 3/8 swiftech barbs.
"All Swiftech water-blocks using the NPSM standard, such as Apogee, Apogee GT, MCW60, MCW30, are compatible with these fittings. "
-From petrastechshop barb description
NPSM is not the same as G1/4(BSP 1/4")
NPT/NPSM are American thread standards and BPT/BSPP is British/European.
For example: Dangerden typically uses G1/4 threads. Aqua-computer uses G1/8, Thermochill radiators have G3/8. Swiftech uses NPT. Koolance...who knows. In essence, thread compatibility can be a nightmare.
---------To answer your question, no, you cannot swap barbs. I have double checked and tested this, as the black Swiftech barbs are NPT and the Dtek blocks I have are all G1/4.
yeah you can make the fit. ive done it. just get some hot water if you need it.
It seems like quite the contradiction. yes the description says that. But look at the title of the product "Swiftech High-Flow Fitting (G 1/4" Thread, 1/2" OD)" and then look at the picture of the product, which says 1/4" BSPP Thread.
Like you said the black barbs are swiftechs 1/4" NPSM. while those are g1/4. look at this linkhere. that says 1/4 NPSM right in the description and also says direct replacement for swiftech products.
After looking at your swiftech res, it is indeed using the black barbs, so it will indeed not work. sorry about jumping the gun. I refer to my original suggestion, boil the tips!
thank you for the insight joecool.
Thanks for doing all the research, guys! It's been a big help!
I'll try boiling the tubing tomorrow. Hopefully, I'm not setting myself up for future leakage problems ...
Just when I thought I had eliminated my WC problems by purchasing the "turn-key" PC4-1025BK, something else had to happen! :p
The journey continues ...
IH8Spam
