rate this receiver
I'd guess that its probably better than anything in the 300$ price range. If you went up to the 1k mark, then I'd bet it would be beaten by a modern receiver like the Denon 3805 in both sound quality and features.
Were I to guess, I'd say that that Marantz would have better sound quality than anything in that price range, but you might miss out on a few features that newer receivers have, like Prologic 2 and DTS:ES. I'd still buy it myself.
klowngoblin said:
i dont think we get those amps here in canada.. never heard of it
Never heard of Marantz? I'm sure you can get it in Canada.
They prolly heard of Philips..
Philips bought Marantz years ago, but I dunno if hte acquisition did anyhting as far as availibility, model changes, etc.
so what's the deal on this DAC stuff? 96kHz/24-bit vs 192kHz/24-bit.....i dont even know what that is but would it make a difference lets say for the purpose of hooking it to a comp qualitywise? i plan to probably get a receiver 250$ that is good for music and movies and just hookin up my consoles for my 2405
DAC stands for Digital-Analog Converter. I dont know about others but Marantz always sounds a little lacking on the middle range to me while some say its very musical. 192kHz/24-bit DACs are a step up from 96kHz/24-bit and usually found in receivers with prices above $500 nowadays. it still makes a difference even you input everything from your PC sound card. It depends on how much you are into hi-fi music playback and the home theater stuff. I dont know how much you are paying but I wouldnt consider it if its over $600.
P.S. I think I might be misleading you so just let you know generally speaking, its still a good receiver even considering its age.
yeah, i was probably thinking about geting a modern one, after all they would all be around the same price. so the "higher" the DAC the better? or can u only notice the difference if whatever source utilized such quality? i noticed some receivers have dacs at 192 for a low price like onkyo or denon. does it make a difference really for normal use?
thanks for all your responses :)
I'd prefer DACs with better specs. The source may not have that much to do with DACs -- higher rate DACs preserve whatever from the source with more fidelity/better soundstage (as a result), etc. Generally speaking, Onkyo, Denon, Marantz, NAD, Harman-Kardon together with Pioneer and Yamaha are major players on the entry level audiophile equipment market. Hardcore bugs most likely use separates or go for B&K, Lexicon and such, which easily cost two grand at least only for a receiver. I know Onkyo put 192kHz/24-bit DACs in their cheap models but be aware regardless the spec, those DACs might be crap. Denon is one of manys favs and as what I know of only models as AVR-3805 and above have that spec and the DACs used are actually pretty good burr-brown. If you dont consider yourself as an *audiophile* and you dont go crazy setting up more than six speakers in your room when watching a movie, that Marantz could be a keeper if you can grab it under $600. I know I would.
I got burr brown dac's in my pioneer elite reciever too.
