Rate My system! :D
Hupo
Ok Whats up everyone? These are my specs
Waiting to arrive in the mail:
1. Abit AV8 Via K8T800 Pro Athlon 64(FX) Skt939 DDR ATX Motherboard w/Audio, Gigabit LAN, RAID/Serial ATA
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=240140
2. AMD Athlon 64 3200+ Processor (Winchester) Socket 939
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80701-2
3.Corsair VS1GBKIT533D2 1GB Kit DDR2-533 PC2-4200 Value Select Memory
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=85016-33&ps=ho1
||Currently Have(Bought from store and new egg)||
1.Ati Radeon X800 Xl 256 mb Agp
http://www.compusa.com/products/product_info.asp?product_code=319371&pfp=search&tabtype=rb#moreinfo
2. ASYS X-60 RobotYLW Black/ Yellow Steel ATX Mid Tower Computer Case 500W Power Supply LED Meter
http://www.newegg.com/Product/Product.asp?Item=N82E16811195018
3. 40 gig maxtor hdd(from 1997)
4. Dvd Cdrw combo drive
What do you all think? :cool:
Under manufacturers specifications..
CPU Integrated Dual Channel Memory Controller
- Four 184-pin DIMM sockets (Un-buffered Non-ECC DIMM)
- Supports Dual Channel DDR 400/333/266 (Max. 4GB)
Plus Im pretty sure that only the latest intel boards are using DDR2 at the moment.
im pretty sure of this too...AMD dont use DDR2. Also, i would get a better PSU. And hand drive. Apart from that its fine.
yeah funny u post 2 different threads about basically the same thing, asking people what they think about your unfinished mid-grade system. not sure exactly what u expect to hear from everyone but most of us have systems that blow away what your upgrading to. either way, u definately need a different HD cause a 40gig from the 90's is just pathetic, lol. when u get the correct ram i would suggest spending a little more, u picked a good brand but never really cared fer the value select stuff. 1 rom seems like a little hassle, i dont think i could even use less than 4 roms nowadayz, but then again im very lazy. gfx card looks alright, and cant really comment on the AMD since i havent owned one in years. btw what screen u using? 15" CRT from 1997? :p
Not everybody is as wealthy as you with your 24" monitor and 2gigs of high performance ram. Give the kid a break
I hope it does! Monday i gotta call them up.....hopefully they can package it that day......or send it.... maybe ill get it thursday....now for the big question... should i wait for my cuz to build it with me?
Don't post a "Rate my pc" thread if your rig isn't better than mine (sig) that I bought on christmas; which is long ago. It's not teh bomb, but people get tired of seeing soso pcs wanting to be rated a completely normal.
