Rate my latest build
I'm waiting for this shipment from newegg:
E6600 cpu
EVGA 680i (TR version)
MSI silent 8600gts
2x1gb DDR2 800 (A-Data, w/ heatspreader)
Centurion 5 case
XCLIO goodpower 500w
The total came to $782.
plus these old parts:
WD Raptor 74gb
dvd burner
Just remember that card is crap for gaming. For DX10 you neeed a 8800gts at least.
what size monitor will you be gaming on, if gaming at all?
I game at 1280x1024, unless I upgrade to a bigger LCD, in which case, of course, I'll play at the native resolution of the LCD because whenever you run an LCD at a resolution other than its native resolution it looks like shit.
Crap for gaming?
E6600 cpu
MSI silent 8600gts
Centurion 5 case
WD Raptor 74gb
dvd burner
DAAMIT! You! You're not supposed to get better hardware than I have! :D
(lol, I always wanted to do that.)
Looks OK, brand names may not be what I want. But, whatever.
I thought about a card like 8600 GTS but I opted for a silent X1650 XT instead. But, I intend to replace it in the next year and put it in my backup system anyway. So... ;)
Crap for gaming?
You are comparing a OC version with a fanless one. :rolleyes:
The only difference between those is a 3.7% core overclock and a 5% memory overclock. I could overclock my passively cooled board a lot more than that, with the draft from my 120mm CPU fan.
Personally, I think you definitely should have gone for at least an 8800GTS 320mb, but unless you're planning on upgrading your video card in a year, then it shouldn't be THAT bad, ;)
you should have bought better video card and ram. It seems like a waste because your motherboard is stable during high overclocking and the video card is only going to manage really basic games. Get some D9's and D10 video card in the future. :p 2 cents
It's built, over, done with. Leave the guy alone.
I think it is a good build and he will be happy with with it. Stop giving him crap about it.
I wouldn't give him crap over his personal choices. But, I later felt a little guilty over the fact that I was too "nice and polite" on my previous post. Fact is, benchmarks can be seen different ways. I only realized after posting that last message that those benchmarks were done with old games.
I can't even begin to explain why that makes such a difference. But, it's like, some games for example can seem to "level off" at a certain level. There are reasons for that and I'm too tired to get into that right now. Suffice to say that video card may not be as fast as you think it is.
