Rate my build
what's the best quiet gpu cooler for the 4850? might as well grab one while i'm at it as the saphire plus cooler will cost the same as the msi without a cooler
pick up a used 8800gts just as good as them..i'm sure you can find a used one for $85, thats how much I got a 8800gt for, since a 8800gts is already a dual slot solution, Heat is not a issue.
At 77% fan speed, I can't hear it, and it doesn't go above 55C
i'm not a huge fan of buying used computer gear, have no reason why, but i just don't do it.
i've also decided to only get 1 hard drive
Gigabyte DS3R $126.99 -$20MIR=$106.99:
http://www.newegg.com/Product/Produc...82E16813128344
Intel Q9660 $189.99:
http://www.newegg.com/Product/Produc...82E16819115017
Corsair XMS 2x2GB PC800 DD2 $69.99-$25=$44.99:
http://www.newegg.com/Product/Produc...82E16820145184
MSI HD4850 $190-$30MIR=$160:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127370
Sony Optiarc 7200S $23.99:
http://www.newegg.com/Product/Produc...82E16827118012
WD 640GB SE16 WD6400AAKS $75:
http://www.newegg.com/Product/Produc...82E16822136218
Xigmatek HDT-S1283 120mm Rifle HSF - $35 & Retention Bracket - $7
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019
now i just need a GPU cooler
ok, pulled the trigger:
1 x ($6.99) CPU COOL XIGM|ACK-I7751 R - Retail
$6.99
1 x ($74.99) HD 640G|WD 7K 16M WD6400AAKS % - OEM
$74.99
1 x ($21.99) DVD BURN SONY-NEC|AD-7200S-0B 20X % - OEM
$21.99
1 x ($36.99) CPU COOLER XIGMATEK|HDT-S1283 R - Retail
$36.99
1 x ($39.99) GIFTS MSI G71-VG31012-SH0 % - OEM
$39.99
1 x ($126.99) MB GIGABYTE GA-EP45-DS3R P45 RT - Retail
$126.99
1 x ($189.99) VGA MSI R4850-512M HD4850 512M RT - Retail
$189.99
1 x ($189.99) CPU INTEL|C2Q Q6600 2.40G 775 8M R - Retail
$189.99
1 x ($69.99) MEM 2Gx2|CORS TWIN2X4096-6400C5 R - Retail
$69.99
1 x ($-39.99) DISCOUNT FOR COMBO #134137 GIFT
$-39.99
Subtotal: $717.92
Tax: $52.05
Shipping and Handling: $19.11
Total Amount: $789.08
i also have $75 in MIRs. Hopefully those all go through without a hitch.
found an evga 9800gtx for $10 less than the 4850 and i personally love nvidia and evga, so i went with that.
