rate my build, low/mid gaming
orubap
The 939 board I've using for the past four years has been resurrected as a WHS box so I'm looking to build my next machine. With the server and backup in place housing all the drives and tuners, for this machine I'm aiming for a simple SFF build.
As a console guy I never gamed on my previous desktop, so while I'm a bit apprehensive of making the switch to a keyboard and mouse, I'm looking to try it this time round. So as well as general duties some light gaming is on the card, such as TF2, CSS, etc and maybe to get the feet a bit wet on the latest offerings.
Build so far looks like this. So the questions are...
1. Will the EA380 power all that gear?
2. Any noticeable benefits in going for the M4A78-VM which is roughly the same price and spec? While similar to the M3A78-EM listed as far as I can make out the M4 has 2 less dimm slots so it would be capped at 4GB, a few less I/O connectors but apparently better AM3 support.
3. Any recommendations or changes?
I'm hoping to get a couple of years out of this machine but if my next upgrade comes around sooner, i.e. if the desktop FPS bug hits me hard then I'll be looking to swap this mobo into a low profile case to spend the rest of its life as an HTPC so it would be good to know if the onboard graphics could handle 1080p video. TIA for any advice.
What size lcd monitor are you using? What is the native resolution of your monitor?
I run a 22" and 19" widescreens but don't imagine my duals would be any good for gaming, so it'd be the 22" at 1680x1050
I would suggest a bit beefier PSU for that 4870 and similar, but other than that you should be good to go, that resolution shouldn't kill your 4870's performance depending on which games we're talking about (there should be very few games that have any major issues)
psu should be fine
would suggest bigger HDD though
you can get the 1tb hitachi for cheap at ebuyer the samsung 1tb f1 is also pretty cheap
1) Definitely, but not much more.
2) Nope, not really. So, if you plan on updating the CPU, you might want to go for the M4 instead.
3) Looks fine to me. I assume all your files will be stored on your server, so no real need for a big HDD.
Thanks all for the replies.
Looking into the drives a bit more, I kinda wish I'd opted for greens when it came to the server. I'll go for the 1TB caviar green with this order and swap it with one of the 500GB caviar blacks I bought for the server.
Last question: would anybody like to confirm that MX-2 does not contain silicone? I read it's something to avoid with the copper on the Xigmatek.
Cheers man. Had come across that page earlier but wasn't sure you could take that to mean there was no silicon present. I'll take your post as a yes though ;)
Heh, I'm not sure if it does or doesn't. Though, if you get the Xigmatek HDT-S1283V (Dark Knight) version, its nickel plated, so you wouldn't have to worry if it did have silicone. ;)
So my 4870 finally came through and being out of the gaming loop I didn't realise modern cards needed two PCIe power connectors :rolleyes:
The EA380 I'm using has a single PCIe power plug, not two. So I'm guessing I should be good to have one wired direct and the other with a molex-pcie adapter...??
Should be fine.
