Rate my Budget Build plx
cxz001
OCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
AMD Athlon II X4 620 Propus 2.6GHz Socket AM3 95W Quad-Core Processor Model ADX620WFGIBOX - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103706
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
PNY VCGGTS2501XPB GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133266
PNY Gift - 3DVISION - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16800996078
Rosewill R230-P-BK Black 0.5mm SECC Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147075
A-DATA 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GB2G9-AG - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409
Subtotal $478.95
Tax $0.00
UPS Ground $12.98
Order Total $491.93
The only things I would really criticize are the 3D glasses, that case is horrible, and the timings on that memory are a bit a high.
Is this a $500 gaming machine your are trying to put together? What's the max budget on this build? What size lcd monitor do you have? I would avoid the X4 620 Propus cpu when it comes to gaming. The lack of L3 cache cripples the X4 620 cpu in gaming. Go with an X2 550 dual core for $99 or the X3 720 triple core for $119. You can squeeze that in if you get the Asus 785G mobo for $85 w/free shipping. Swap the OCZ psu for Corsair 450VX for $64.99 w/free shipping. I'd stick with those A-Data Ram for $70 w/shipping. That's a good deal especially when you're on a budget.
Whatever HG said above hardware wise, FOLLOW IT!!!!
It's excellent advice :)
