Raspberry Pi Off To Manufacturing
They say Android wont work on it with the limited RAM but I wonder if after this is out maybe there will be some custom ROMS made for it. It would be cool to see Cyanogen support this device. Being the OS is kept on the SD card it would be really cool to just turn off the device and swap out SD cards to switch from Linux to Android and vice versa for different things.
I can see a lot of development surrounding this device. 3d printers making cases, custom Android and Linux Distros. I'm pretty excited about this.
android should run fine on it, my samsung intercept has (from what i can tell) 128mb of ram, if it has 256 then it hides 128mb from every task manager i've found...
my phone before this, the htc hero cdma, had 256mb of ram on a 600mhz processor, the Rpi has plenty of ram to run android
Can't edit post, but from a little google-ing several sites seem to agree that these are the minimum specs for the android OS
32MB ram
32MB Flash Memory
200mhz Processor
I'd also be really interested in seeing one of these running Chrome OS. It would be nice to set one up next to the TV and be able to use it to stream Netflix, HULU, etc. It would be a browser equivalent to ROKU or something. Unfortunately I think Netflix instant watch currently doesn't work with Linux. It does work okay with Chrome OS.
A computer the size of a usb stick. Pretty f***in' awesome if you ask me. Would be a fun hobby computer to make some small robotics perhaps.
I don't think it's powerful enough for flash video at a decent framerate.
The released verison will be about the size of a credit card but that's still pretty small!
Needs a version with two network ports for finally reasonably priced network appliances. I'd buy one in a heartbeat.
Seriously other vendors want ~$200 for basically the same thing.
I'm in! Those things are awesome for things like automation. Imagine using it with cams via ethernet, Profibus etc....
Well you can always buy a USB -> Ethernet adapter but the problem is that both ports would be sharing the same bandwidth, as well as with any USB devices you have attached.
It has hardware decode. It should be able to do it if your flash player supports hardware.
This is a ideal candidate for an Android port.
if you are not in hurry save 6 month and it'll have more decent system for same price and may be better considering all the bugs and stuff are gonna get worked out. i would like to see this thing in metal case or platform just to be safe from heat compare to plastic casing which i'm sure what first few versions will have.
I am have been contemplating building my 5 year old a system for a while.. That is enough justification for me to order one & my sister who doesnt have a computer will also order one (they have the internet for game consoles already)
does not ship with a case at all. wysiwyg.
I've been calling the Raspberry Pi a Sheevaplug killer for good reason. Couldn't have come any sooner.
As long as I can screw around with values and can make it have a blue background it's a bios! :D
Damnit...5v input only...might be more difficult than I thought!
Nope, you can't. If you "screw around with values" on a bootloader, you brick the system. There is no BIOS screen, there are no BIOS like settings, there is no menu to choose options from, there is simply a bootloader that is configured to look for a binary on EMMC.
THERE. IS. NO. BIOS.
AT ALL.
Period.
5v input. AKA USB.
You really don't know what you're looking at, do you?
Dockstars. About the same size once you strip the case.
Sheevaplugs. Ditto.
Beagleboards. A bit bigger but same idea.
Gumstix. Smaller and more expensive, but still a computer the size of a USB stick.
Here's something shocking.
Your smartphone? Also a computer. And virtually the same hardware as all of the above. Including the Raspberry Pi. ARM SOC's with everything else connected to it.
Hell, your dumbphone? Also a computer. Just with really shit specs compared to a smartphone. If your Smartphone can be considered a Pentium, then the dumbphone is more along the lines of an 8086. In the end, it's all still ARM based.
