Raptors Low Benchmarks, Old HDD Higher Help
Redleader
I bought some raptors last week and installed Windows XP and reinstalled all my stuff then I ran 3DMark05 and some others and my benchmarks suck with this new setup. I thought I might have messed up my hardware but then put my old hard drive with my old XP install on it, booted it up and ran 3DMark05 and scores go back to normal. Anyone have any suggestions?
On Raptor: http://service.futuremark.com/compare?3dm05=2816981
3dMark 3603
CPU Score 1143
Old HDD: http://service.futuremark.com/compare?3dm05=2820754
3dMark 5888
CPU Score 4665
I highly doubt it has anything to do with the hard drives.
You probably have something screwed up or at least different on your new install of XP that is causing your performance loss.
Its not the hard drives themselves but it is something. Anyone know of settings that could screw up performance that bad? Ive checked all I know and all are the same.
I did a fresh install again on a ide hard drive and still getting these low scores. It has to be some settings but I still cant figure out why. They are in DMA. Anyone else have any suggestions?
I would stop looking at the hard drives all together. The drive is not figured into your 3D Mark score. It most likely is a driver. Make sure you are running the latest ones for your hardware.
If you want to test the speed of your hard drives and the controllers use HD Tach. http://www.majorgeeks.com/HDTach_d672.html
I know it is not the hard drives. Got an suggestions on what settings could be screwed up? Ive tried two sets of drivers and both give same scores. My gpu and cpu scores are low in both 3DMark and PCMark so something is screwed. Could a bad mobo do this?
Have you installed the NForce platform drivers?
Download SiSoft Sandra and run thru its little applets and see if something comes up red flagged.
Well I really dont know what to say. I guess Im just an idiot. Thanks bud that fixed it.
