Raptor Question
iLLuSioN
Well i just got a new raptor and installed it as my boot drive(cloned my old 80gig WD)
The problem is i dont notice a difference in speed at all and boot time seems to be the same.
Heres my hdtach results:
Also had a different problem now, since ive installed a new wireless mouse its weird when i move it around alot my cpu utilization goes up to 80% from 0, and when im running azureus i cant do anything with my comp but surf the internet cause the mouse lags for a second then jumps to where it should be constantly...its EXTREMLY ANNOYING! anyone have any idea?
Are you using a secondary sata controller (like as in one thats not on-board)
also, what board do you have?
Its plugged into the sata1 slot on the motherboard which is an Abit IC7 MAX-3
always do a clean install on new drives to eliminates existing probs.
18% CPU utilitization? I relaize that HDTach's CPU use measure isn't very precise, but 18% for a storage device in a linear transfer test is unacceptable by any standard. I'd be looking on Abit's or Intel's support sites for updated chipset drivers.
I'd also want to check for bloat/malware.
DougLite said:
18% CPU utilitization? I relaize that HDTach's CPU use measure isn't very precise, but 18% for a sotrgae device in a linear trnasfer test is unacceptable by any standard. I'd be looking on Abit's or Intel's support sites for updated chipset drivers.
Ok ill check that out. Anyone have any idea with the mouse problem?
