Yoshmaista
- Jan 5, 2004
Been having a problem that has developed just within the past few days. My computer is randomly just completely shutting itself off. It's not doing any specific intensive task or anything. I'll just be listening to music, and BAM, shut down. I will have to wait at least 2-3 minutes, then I can turn it back on again. It will go for 2-3 days, then will shut off, repeat process, etc.
Things to consider
1. I replaced my Power Supply not to long ago with a an Antec 550Watt . I've been monitoring, and all voltages are fine, as far as I know. (BIOS reporting 12.09 on the +12V,3.33 on the 3.3, and 5.01 on the +5V). I've had the PSU for about a month or two and its' been workign completely fine. It has more power then the last one that I had, which had lasted almost 2 years.
2. All temperatures are fine. CPU is colled considerably, all hard drives are fine, PSU temperature is fine. GPU seems a bit high for idle (around 58C), and for load (round 80C load).
My motherboard is about a year old, and for the record, it's an MSI K8N SLi Diamond. My bet is on the motherboard being faulty. If the PSU was bad, most likely it would be randomly restarting, not completely shutting off. Same with bad RAM (which I just got new sticks of from Crucial). If I had to guess anything right now other than a motherboard, it would be the GPU. However, the only thing that debunks my theory about that is that my computer will shut-off just idling (so the GPU isn't even under heavy load).
Any help is appreciated, thanks a bunch
Things to consider
