I have an athlon XP 1700 thoroughbred OCed to 1710 mhz. The voltage is currently set at 1.75
Every once in a while it just restarts while I am playing a game or during similar activity. I am running winxp pro
think this is a stability issue? I had it at 1.7 volts and I jumped to 1.75 to try and fix the problem, but it has not eliminated it. Ideas? The cpu temp is only around 40 when it shuts off (sometimes even lower, i have never seen it over 45)
Thanks!
Thanks!
