Random reboots
Hollow4
ok heres the deal. i built a comp for ym folks like two or three summers ago whenever 2500xp was all the rage. well it just randomly reboots at will. youll be surfing the net and all of a sudden the asus boot screen comes up. it doesnt happen at regular intervals at all, nor do i think its a heat issue. so its been happening for a couple of years now and they are about ready to throw it out the widow apparently i havent really been home much to fix it. its an asus kv8 something or other mobo(am at work now). im wodering what might be the cause of this. im think about pulling the board and sticking an abit board in and calling it a day, as well as buying them an SATA harddrive and a new video card cuz dad like my dual screen setup. i guess my question is, am i correct in assuming that it is the mobo causing these problems??
Check the power supply! If you've got a cap issue in the supply, it could just be overdrawing the power, and therefore resetting the mobo.
The only way to check is to replace with a known working power supply and see if it makes a difference.
Depending on what hardware has been added over the years (including USB peripherals that draw their power from the board) it may just be an overdraw situation. Considering the timeframe though, I'd be guessing that it was just time for one of the capacitors to no longer be able to hold the closed circuit under nominal heat levels.
If you find out that it’s not the power supply, next place to check is memory. Run a scan with Memtest86 and you'll know if there's a bad spot on the RAM or not.
well that sucks i really dont want to do all that crap. bahh ill check the psu and if doesnt work ill just grab a new mobo and video vard and some new harddrives. hell i may just upgrade the whole damn system for him so i can throw things in for my too :D
Keep in mind doing the testing will prolly get you a simple fix. Much more simple, and less time consuming than replacing the guts altogether ;)
Another thing might be the fact that after a while you might need some extra voltage to hold your OC. You might be having some stability issues because of your OC. Try lowering to stock speeds/voltage and see if you get the same reboots. This assumes of course, that you're giving it some extra VCore ;).
no i wouldnt oc this computer. its used mainly for my moms super ridiculous sewing machine and Itunes. who needs to oc a computer thats not even using half of its potential.
ill look into it this weekend. luckly i also have a similar setup so swapping parts should be that big of a deal. but seriously what a friggin headache to do all that crap.
run memtest first, it takes only a few minutes to download and start. but I would bet it is the power supply. make sure the pc is on a good line conditioner, and that that line is not running a refrig and ac unit with motors fouling up that wall socket and the computer. the last thing would be to rebuild the pc.
Some models of Asus borads had issues with the Antec 420watts, so maybe yours is having trouble with the 430?
