Recently went from a XFX 290 DD to a Zotac 980 AMP!
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150697
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500361
Psu is a XFX Pro 850
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207028
I have selected high perf in windows, tried each oc tool to force overvoltage and also run the card with no oc and no overclocking software either.
PC still reboots. I have not seen or been able to find a crash report.
The pc just reboots. No bsod. The only other weird thing it did was have sound issues. Like you could hear the gpu running or just power flow effected static.
In game, no crashes. Just in either windows idle or when I load the start screen to a game.
Derp? I thought it was some setting. It appears to be something else? The two gpus use different power plugs. The 290 used two more actually.
