evilchinesefood
- Oct 8, 2009
Ok I'm new here guys so hello. I recently built a brand new computer. 5th build. This time I had little more money than previous builds so I was able to get more exactly what i wanted.
Problem arises with it though. It randomly freezes at start up (Windows loading screen and sometime right after all the programs are loaded and ready for use) and then It freezes when I try and run OCCTP or Prime95, normaly first 10 secs or so. Sometimes there are lines on the top of the screen and other times there are messed up pixels. Other times theirs nothing.
Build
AMD Phenom 2 X4 955 Quad-Core @ 3.2ghz AM3
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler
ASUS M4A785TD-M EVO AM3 AMD 785G
Mushkin 4GB (2 x 2GB) DDR3 1600 (PC3 12800)
NVIDIA GeForce GTX 260 896MB EVGA
CSB X-Fi XtremeGamer Fatal1ty Professional Series
500GB 7200RPM / 320 GB 7200RPM Storage Drive
Windows XP SP3
Programs Running
Norton 2010
Mozy Online Backup
Skype
Steam
Gmail Notifyer
ASUS EPU Engine (I think this is the problem)
Bluebirds
Nvidia Control Pannel
Now with ASUS EPU Engine it came set for performance mode and that is how i have had it set, cpu runs about 37c and 43c under load. When i switched it today to Power Saving (Which turns voltages for Vcore and VDDNB down slighly) it runs about 31c idle and about 34c Under load. THe problem appears to be fixed when its set for power save mode, but my sound seems to crack a bit. Lots of pops and scratches in the sound. Doesn't sound good on the speakers. When its up it does not do this.
GPU Temperatures are about 45c Idle and 49c load. Nothing is overclocked all factory defaults. BIOS is update and all drivers are up to date. Windows is up to date too.
NOW:
My computer froze and I had to restart except this time when i restart i cant see anything. So i took the side off and tried plugging the DVI cord into the mobo connector. No luck, Took the GFX card out and tried again and it boots right up.MY computer is also running almost 15c lower too with the side off. I have a COOLER MASTER COSMOS 1000. Is that normal for it to drop that much? Any ideas, GFX card the problem or is it just gone bad?
EDIT: Well i tryed some more with it. I uninstalled my NVIDIA drivers and tried again. I also tried the other dvi ports on the card. Both turned up nothing. The screen is getting a signal because it says there is a signal on my monitor. Otherwise nothing happens.
This was my post to evga about my graphics card problem. They never answered. Im hoping you guys can help me! IM getting desperate and uneasy.
Build
Windows XP SP3
Programs Running
Norton 2010
Mozy Online Backup
Skype
Steam
Gmail Notifyer
Bluebirds
NOW:
