johantheolive
- May 28, 2006
I just built a new system from scratch for my dad about two weeks ago. Everything works fine, except one thing - randomly (it seems that way at least) the monitor goes black and the computer locks up, won't respond to input. Then you can hit the reset button and it goes back to working fine. The thing is that it doesn't happen regularly at all, it went a few days without a problem then yesterday and today it did it once. I reset the BIOS to the default settings just to be safe and it didn't help. The only setting I wasn't sure about was the SATA IDE type (options of native ide, legacy ide, IDE->AHCI, and RAID). It defaults to native and i swapped it to legacy (not sure what the difference is). Anyways, that seems to have not helped (in fact it appears that the system is crashing more often with the setting changed). I thought maybe its overheating, but after a crash it was at 40C which isn't hot. The problem is that I can't replicate the problem, nothing seems to really provoke it and its a Foxconn board that doesn't seem to even have a manual (in box or online). I ran Memtest and it didn't send me any errors and I stress tested the CPU to make sure it wasn't that and it ran stable.
The specs follow:
I'm going to run a hard drive stresser next time I'm there and see if that turns anything up. I'll run memtest again, but i don't think it's that. I also thought that maybe the integrated gfx is acting up or the drivers are just buggy since the 690g is a newer chipset. Anyone had any suggestions on what to test? Thankies.
The specs follow:
- Athlon 64 X2 3600+ Brisbane 1.9GHz Socket AM2 Model ADO3600DDBOX
- Foxconn A690GM2MA-8KRS2H Socket AM2 AMD 690G
- WINTEC AMPO 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Model 3AMD2800-1G1K-R
- HITACHI Deskstar 7K80 HDS728080PLA380 (0A30356) 80GB 7200RPM SATA 3.0Gb/s Hard Drive
- And a DVD-ROM drive I had lying around
