Ram Problem BSOD
I just got 4 sticks of OCZ400 Platinum REV.2 512mb RAM from my bro. It ran fine on his comp but when i try putting it in mine i start windows and immediately get BSOD. I tried different configurations as in, increasing DDR voltage to 2.8V and Increasing the Memory Timings. I also tried doing auto configurations. I have an Asus A8N Sli Deluxe motherboard with Phoenix-Award BIOS version------- "A8N-SLI Deluxe Bios version 1016"
My original ram was 2 sticks of Corsair400 512 mb RAM
What should i do?
Different BIOS?
Motherboard Problem?
Probobally not a RAM problem cuz it worked just fine on my bros comp
Make sure your Command Timing Rate is set to 2T, instead of 1T. I could be wrong, but I am pretty sure that when running 4 sticks you must use 2T. 1T will only work with 2 sticks.
What CPU are you running? Maybe you just have an iffy memory controller on your CPU that doesn't like 4 sticks. How do they work when you're only running two?
Does your RAM work when you're running 2 sticks? Or even each individually? Maybe one out of the 4 is bad.
It works when im running my 2 corsair stix
I am yet to test it on the 2 ocz stix
Oh and my bro has my same processer athlon 64 3500+ except its dual core... and again the 4 sticks work fine on his comp.. so taht rules out ur theory (Even if it may be true)
I have tried mixing my two corsairs and my two oczs and ive upped the timings and that got me intoo windows but neverwinter nights 2 just dumped on me
another update
I got into windows with all 4 ocz sticks but they are underclocked like shit!
Frequency is 134 mhz
Cas Latency 2 clocks
RAS precharge 6 clocks
Bank Cycle Time 13 clocks
Command Rate 2t
DRAM idle timer 16 clocks
It sounds like your memory controller on your 3500+ isn't as strong as your brother's 3800+ X2.
