Hey, I recently made a new build and have had problems with it crashing from the get-go. I invested in a pretty heavy duty cpu cooler because I thought that it may have been the processor overheating (nothing is oc'd by the way). Anyway, after installing the new cpu heatsink/fan the problem persisted, actually intensified slightly. When it crashes (normally while gaming) the computer completely locks up and the audio skips rapidly, machine gun-if you will, and there is nothing to do but flip the switch. After messing around with some more stuff I pulled out a stick of my RAM (right after a lock up), (gskill 2x1gb) and it was scorching, leading me to believe that this may be the source of the problem.
As far as my air flow goes i have a side fan blowing directly on the side of the heatsink/cpu thing I installed, and the regular intake from the front. I faced the heatsink/cpu directly to the back where the exhaust is. The RAM is to the right of the cpu like on most mobo's so it kind of makes sense that it isn't getting much cool air.
Does anyone have any good suggestions as far as getting some better airflow to the RAM or products to use (without going crazy). Or if you believe the problem is something else, let me know. Here are my specs:
intel 6420, cpu
gskill 2x1 gb, ram
msi 8600 nvidia 256mb, video card
520 watt corsair, psu
arctic 7 cpu cooler
asus 650i mobo,
Thanks for any feedback.
intel 6420, cpu
gskill 2x1 gb, ram
arctic 7 cpu cooler
asus 650i mobo,
