Ram Configuring
Hayden123
Hey I bought 3 gbs of samsung pc-3200 ddr 400 low density ram for my mobo which is Foxconn Winfast K8S755A-6EKRS and am not sure how to configure the ram for most stablitity and best performance. This is my first build so any tips are helpful.
I am really not all too sure what I am doing since I am still a noob and I have read so much on this computer stuff that I thought I had an idea on how to get it to work right. I have a new found respect for all hard forum guys because they build so many computers.
I have the hole thing running on just auto BIOS settings for the ram and I keep getting stop errors. I kinda figure its the ram because every thing else seems to be working correctly.
The specs are
Amd 64 athlon 3200
Ati X800XL AGP 256mb
Raidmax 420 watt psu
Western Digital SATA 300 250gb HDD
sry that specs so low thats what happens when you stick with your old AGP card
auto setting on the ram is probally best right now.
Download this (the .iso file or the floppy file) and burn a CD with Nero or whatever and test the memory.
http://www.memtest.org/#downiso
This creates a CD/floppy/thumbdrive you will boot from and will test your memory.
Next time write down the stop error numbers and post them.
As far as I can tell your memory is (if the picture is correct and you have 8 chips all on one side of the memory stick circuit board) single rank x8 type memory. According to your manual
qty _ type in slot 1 ________type in slot 2__________ type in slot 3 _____ 1T _ 2T
3 _ x8 single rank or x16 _ x8 single rank or x16 _ x8 single rank or x16 _ 166_ 200
You can run 166 at 1T or 200 at 2T and everywhere on the net I see running only 2GB in that board is recommended, including me in reply to your first post. So if you run memtest and find errors, the first thing I would do is yank out a stick and try again. I am hoping your stop error is not due to memory. There is a good chance it is not. Make sure you have the latest bios update installed. Where there any issues installing the motherboard drivers ? Are there any yellow warnings or red marks in Hardware Device manager in windows ?
If possible stop buying computer parts from ebay, you did not get a good deal.
http://www.directron.com/ddr4001g.html#caption
1T/2T Memory Timing (Default: Auto) (Optional) <--------- 2T
The available setting values are: Auto, 1T and 2T.
&#56256;&#56473;Max Memclock (Mhz) (Default: Auto) <---------------------------- 166
The available setting values are: Auto, 100, 133 and 166.
&#56256;&#56473;CAS# Latency (Tcl) (Default: Auto) <-------------------------3.0
The available setting values are: CL=2.0, CL=2.5, CL=3.0 and Auto.
&#56256;&#56473;RAS# to CAS# delay <Trcd> (Default: Auto) <-----------------------6
The available setting values are: Auto, 2 - 7 Bus Clocks.
&#56256;&#56473;Min RAS# active time <Tras> (Default: Auto) <----------------------12
The available setting values are: Auto, 5 -15 Bus Clocks.
&#56256;&#56473;Row precharge Time <Trp> (Default: Auto) <---------------------------6
The available setting values are: Auto, 2 - 6 Bus Clocks.
that is loose timings for starters until memtest reports no errors .
Bill if i were to buy one of these types of ram which one would you choose I've just been wondering
http://www.newegg.com/Product/Produ...2E16820231032,N82E16820227210,N82E16820231031
one of them in there is the one you picked out earlier
and would they all work right
All of those list a voltage specification of 2.6V or greater. I seem to remember the stock voltage of DDR is 2.5 volts and I do not recall seeing the ability to change/increase memory voltage in the bios (might be wrong about that, check me, If you can raise the voltage you probally can get it to work. ).
To be honest I am scared to death to recommend any specific ram for that board. I have done some research and it is very picky with poor support from Foxconn. I just did a google search looking for someone with that board that had 2 or 3 GB installed to see what they used and worked, I found nothing specific.
I did find several sites if you google "K8S755A-6EKRS memory" that claim to have memory that will work. What is not known is if someone just added that board to the list and picked memory or if it was actually tried. Several sites warrantied the memory to work but thats all and fine except if you have to send stuff back 3 or three times to find something that actually does.
I also am worried that while you may have done testing or by being in front of the computer done or learned things that make you suspect your current memory, you have not reported any results. I really wish to help but am not confortable saying buy this, buy that, when you are having issues but we really do not know what the root cause is.
So I am going to slink off with my tail between legs.
