raid zero for the OS...with 2 data drives...what do I need?
surfbug
Hi,
I ahve a dell XPS system, listed in my sig
I have two WD 640gb caviar black drives
I also have two 500 gb WD blue drives, and a 1TB black drive by WD
so, I guess I need a raid controller..for the two 640gb blacks..to set up RAID ZERO
do I need anything else for the data drives? or can I use the connections on my motherboard?
what do I look for when buying a raid controller? can anyone reccomend one?
thanks
al
If RAID 0 is all that you're pursuing, you can get by with just about any inexpensive RAID card. However, I can't recommend a "good" card.
IIRC, you'll need to reformat your system and install the RAID drivers before you install your OS.
The rest of your hard drives can be connected to the motherboard, provided that you have enough SATA ports for them.
Keep in mind that RAID is not a back-up solution, and RAID 0 offers no guarantee on system uptime. In other words, should one drive go bad, you'll lose the entire RAID array.
thanks....yes, I read about the RAID configs....I think raid 1 is three drives, two data-one parity, and then you have data protection, right?----well, one step at a time...raid zero first.
so, just any raid 0 basic controller will work
do I have to get any special "designations", such as 2.0, PCIe., or anything like that?
oh, and reformat? I have to do that anyway, my vista system crashed- I plan to load win 7 from a USB
(so many plans, so little time, haha)
thanks!
Allen
Common ones are:
Raid 0.................stripes the data to read/write to all hard drives at the same time. *Fastest performance
Raid 1 or 1+0.......1 data : 1 backup (requires even number of drives). Raid 1+0 is faster with 4 or more drives (striped array). *Best redundancy
Raid 5.................striped with 1 redundant drive (requires 3 or more drives). *Faster performance than Raid 1
Raid 6.................striped with 2 redundant drives (requires 4 or more drives). *Faster performance than Raid 1
MB raid? is that motherboard raid? I will look in the bios
would that be in the disk management/disk boot area? where would I look?
thanks
allen
It's probably under "Storage" or HD configuration or something like that.
Maybe your manual would have the BIOS options?
But seriously, if you haven't done this much research, I'm gonna suggest you hold off a little?
maybe baptism by fire?
I have an hp mini 110 portable laptop , and a compaq amd that takes pc-3200 memory as my two backup machines...
slower than the i7 dell xps, but I can work off them.
so, with an internet connection, I will research as I go along...;)
thanks for the info so far...allen
ok--
so daily backups?
and the true image software? do I need to do anything else?
any tutorials out there on installing RAID 0?
thanks, allen
Here's an install guide for Vista with pictures.
Sometimes pictures are worth a thousand words. ;)
I recommened Acronis as a backup program because it's saved my buns many-a-time in the last 8-9 yrs and it's very reliable.
Your backup schedule can be anything that feels comfortable to you. I usually do it once a week or when I install a new program or other major change.
Acronis will give you the option to make incremental backups but since I keep my OS on a seperate drive and it's only 25-30GBs, I make a new complete backup every time and delete the old one.
All of my data is kept elseware and a complete OS backup only takes 10-12mins.
