nobody_here
- Feb 1, 2006
Setup is now a single 320Gb WD Blue AAKS SATA 16MB cache drive as primary OS with WIn 7 x64 installed
also have a 250Gb Seagate Momentus used a back up drive (using Win 7 backup feature)
then an 80Gb old IDE hard drive.....
so what i do now is anything i want to keep i drop on the 80Gb drive, then i have the 250Gb drive set to backup the 80Gb drive contents only so i have some redundancy
i am building a new system from the ground up in a few days just waiting on parts to come in
ordered a 320GB WD BLue AAKS drive to match the one i have now
want to RAID 0 the 320's for performance reasons, but it would be nice if i didn't have to format and start over from scratch, but if hardware RAID set up before OS install is the best performance option then i will
but then what should i do with the 250Gb drive and 80Gb drive? i am going to put the 250Gb drive in a 2.5" eSATA enclosure i have because my new mobo has an eSATA port on the back, so that external drive will become the new backup drive
guessing i should just retire the old 80Gb HDD and let the 250 backup the important parts of my main 640GB OS partition.....or should i partition it off? does RAID affect that?
first time going RAID, wondering what you would do
