CrazyBeaner
- Nov 21, 2006
ived seen a pci raid card for ide, so does that mean any 2 ide harddrives with the pci card will be automatically raided or do u need identical drives to do so
CrazyBeaner said:ived seen a pci raid card for ide, so does that mean any 2 ide harddrives with the pci card will be automatically raided or do u need identical drives to do so
CrazyBeaner said:so if i get another 250gb ide same space cache, rpm and i plug in the two hds would it act as one?
It depends on whether you configure the controller to do this or not.CrazyBeaner said:so if i get another 250gb ide same space cache, rpm and i plug in the two hds would it act as one?
both, i was gonna go sata but the same hd i have now is 60 bucks, and the sata hd i want is over 100 (500gb), so raiding them will be betterdekard said:yes... are you doing this to gain more capacity or speed or both?
CrazyBeaner said:yea but its expensive though 2x160gb/16mb cache in raid 0 is around 80 bucks less and perform better
