crystalline
- Nov 25, 2006
In the middle of the night last night, an alarm starts blaring from my case and wakes me up. yeah, 9am IS the middle of the night, when you go to sleep at 5, lol. I'm startled/terrified/confused, the last thing I wanted to do is troubleshoot this piece of crap, and I desperately wanted to return to sleep, so I just shut it down (properly, through windows) and decide to forget about it in the morning.
Turns out that the incident happened in the middle of a scheduled virus scan, and it generated a load of errors in Administrative tools -> Event Viewer. The cause was either one of my drives, or the RAID card itself, somehow losing its connection to the drive. Drive failure seems more likely, but this drive is new, and has only been in use for about 2 weeks. Why would Seagate give 5 year warranties on drives that die in less than a month...
The drive is a 500gb Seagate ST3500630AS (http://www.newegg.com/Product/Product.asp?Item=N82E16822148136)
RAID card is HighPoint RocketRAID 2300 (http://www.newegg.com/Product/Product.asp?Item=N82E16816115029)
This is the message shown in the "HighPoint RAID Management Console":
From Administrative Tools -> Event Viewer, a bunch of error incidents are reported. Event IDs: 9, 12, 15, 51, 57. Error 15 is given 11 times, error 51 twice, the rest once:
There were 4 of the application popup windows, listing 4 different folders ("Delayed Write Failed: Windows was unable to save all the data for the file M:\.... The data has been lost"), but weirdly enough, I'm now able to access all of the folders that were listed in the errors, even though "the data has been lost".
This is the report from Speedfan:
The errors here seem troubling... I've run a few Western Digitals through the Speedfan utility, drives that had been used for 3+ years, and they were rated 100% across the board except for power-on hours.
Are these results typical of Seagate drives?
Should I ignore this incident, or RMA this drive?
Any other diagnostics I should try first?
thanks for any help...
3/3/2007 8:55:27 AM
Disk 'ST3500630AS' at Controller1-Channel4 failed.
Event Type: Warning
Event Source: Disk
Event Category: None
Event ID: 51
Date: 3/3/2007
Time: 8:55:24 AM
User: N/A
Computer: ANONYMOUS
Description:
An error was detected on device \Device\Harddisk7\D during a paging operation.
Event Type: Error
Event Source: 2310_00
Event ID: 9
Date: 3/3/2007
Time: 8:55:35 AM
User: N/A
Computer: ANONYMOUS
Description:
The device, \Device\Scsi\2310_001, did not respond within the timeout period.
Event Type: Error
Event Source: Disk
Event ID: 15
Date: 3/3/2007
Time: 8:55:39 AM
User: N/A
Computer: ANONYMOUS
Description:
The device, \Device\Harddisk7\D, is not ready for access yet.
Event Type: Warning
Event Source: Ftdisk
Event Category: Disk
Event ID: 57
Date: 3/3/2007
Time: 8:55:39 AM
User: N/A
Computer: ANONYMOUS
Description:
The system failed to flush data to the transaction log. Corruption may occur.
Event Type: Error
Event Source: PlugPlayManager
Event ID: 12
Date: 3/3/2007
Time: 8:55:39 AM
User: N/A
Computer: ANONYMOUS
Description:
The device 'HPT DISK 0_2 SCSI Disk Device' (SCSI\Disk&Ven_HPT&Prod_DISK_0_2&Rev_4.00\5&7345b61&0&020) disappeared from the system without first being prepared for removal.
Event Type: Information
Event Source: Application Popup
Event ID: 26
Date: 3/3/2007
Time: 8:55:39 AM
User: N/A
Computer: ANONYMOUS
Description:
Application popup: Windows - Delayed Write Failed : Windows was unable to save all the data for the file M:\$Mft. The data has been lost. This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere.
