I have an ARECA 1230 controller and setup a RAID5 with four 2TB WD and all is working well. Yesterday I decided to use online expansion and added four more 2TB WD drives for a total of eight drives. I used the raid web console to expand the RAID set and it took about 22 hours. Now I need to modify the volume set since I want to just have one drive to take the entire space (raw 16TBs). When I try to use the web console, it won't work because it keeps saying that I need to confirm the operation even though I have the "confirm the operation" box checked. So I thought I would try to use the BIOS but now I am worried that I might loose my data. Will modfying the volume set cause my data to get wiped? Any ideas why the Raid web console will not work? After modifying the volume set I assume I will need to increase the partition size in windows 7? Can I use Disk Management in W7 or should I use a third party software? Sorry for all the questions but I jus want to make sure I do this right and not loose all my data. Thanks
