raid 0 vs. raptor
schnell
which would be faster?
2 80gig 7200rpm drives in raid 0
or
1 150gig raptor 10000rpm
it would depend on the application.
but from a simple "faster": The Raptor spins at 10000, while the RAID only goes 7200.
2 80gig 7200rpm drives in raid 0 or 1 150gig raptor 10000rpm
Look for benchies posted here and on other forums. You should easily find tests of both.
Brahmzy said:
RAID0 Raptors FTW.
... and this answers the given question, how?
The single Raptor will be faster in most single-user apps, almost certainly including games.
thats what i figured thanks for the confermation
great link btw thanks fugu
fugu said:
Assuming spherical hard disks in a vacuum, they'll both fall at the same speed. With air resistance, I think the single Raptor will fall faster, especially if you drop the RAID card with the other 2 disks.
http://storagereview.com/articles/200406/20040625TCQ_5.html
I'd stick with the single Raptor
You sir are incorrect, the new raptor has ribbed sides, leading to greater air resistance. The two single raptors can make a V formation, easily cutting through the air, even with the raid card sitting in the V. Jeez man, learn your physaks.
