Raid-0 current drives or Faster single?
oshia86
Been a long time since I've added new hardware to my machine (long for me anyway). Have been getting my modding fix with the car for the past year or so. Anyway, I am looking on upgrading the HD portion of the computer. Current drives are listed in sig, consisting of two WD 320gb (single platter) drives and a wd 500gb. I am debating on either putting the two current wd320gb drives in a raid-0 config, which I prefer, assuming they will be the fastest option. The other choice would be to go with something like a larger single drive such as a Samsung F3. For the two drives in Raid-0, I am in need of a good cheap hardware controller, which is a piece of hardware I really don't have much knowledge about.
So I am stuck at either finding a cheap hardware controller or if the cost it to great then jumping to a single larger drive. What are your thoughts/opinions? Can anyone recommend a controller making these two drives worth staying with?
If you're only looking for RAID 0 (striping) you can use the onboard RAID system on your motherboard, with little or no performance penalty.
Dustin
Dustin
This actually brings up another question. With this solution I would need to run these as a dynamic disk right? I'm currently still using the beta for Windows 7 and was gonna get my own copy when I get the hard drive situation worked out. Doesn't only the Ultimate versions support booting from a raid-0 config? Which in turn costs me more than going to a home premium copy. And to add to my raid noobness, will I need to run dynamic disks even with a hardware controller?
Edit: Just checked on the board, no onboard raid. Still looking for a good recommendation for a hardware controller or if I am gonna be best going another route.
Dude, you got it wrong: All versions of Windows 7 can boot from a RAID 0 config. And no, you don't have to run dynamic disks.
Don't bother with those. Those cheapies tends to use the same slow Silicon Image chip. Try to stick with controllers made by Highpoint, 3Ware, Adaptec, Areca, or LSI.
