I'm currently water cooling my 4770k (4.6ghz) and 2 x 290x GPUs with an XSPC EX360 360mm (30mm thick) radiator and an EK CoolStream XTC 280mm (55mm thick) radiator.
I'm looking to upgrade the EX360 slim radiator to something a little better and maybe even use lower rpm fans for reduced noise.
How much benefit do you think I would see if I replaced it with a 420mm or 480mm (60mm thick) radiator?
I have a Corsair 900D case so I can fit any radiators up to 420mm or 480mm.
Thanks for your help!
