Radiator above resevior?
JLangevin
Probably a stupid question, but when you bleed the system, you obviously want the res at the very top of the loop so the air can get out of the system... My res is a 5.25" Bay drive and sits above the loop, but I am considering adding another 120mm Fan to the top of my Antec P182 and add a double 120mm Rad... This will place it above the res....By placing the radiator at the top of the loop after bleeing, will this cause the air to become trapped inside it?
Im concerned that once the system is bled, and then moved around, that the air will find a way to settle in the radiator.
If the water level in the res is higher than the level of the inlet barb of the res, you're fine.
Great, thanks. I was thinking that as well.... as long as the air has a place to collect, and not be reintroduced back into the system, there shouldnt be a problem.
My reservoir is a few inches below my radiator. No matter where you put the rad in a closed system it all works about the same. Seen people put Aquatube's at the bottom of the case and no problems. The air eventually gets back to the reservoir.
All I can say is what happened with mine. In both my systems the rad(s) are mounted in or on the top of the case, one with a fill T that connects near the bottom of the case and only comes 1/2 up, The second with the reservoir at the bottom of the case.
With both machines (haven't messed with the fill port one in years other than to top off) I had no issues. Thre first machine I spent a couple of hours picking it up and tiliting it around and basically worrying about it and trying to get every bubble out till I exhaused myself. The newer machine with the res at the bottom took about 10 min to push 95% of the air out of the system, I then placed some books to tilt the machine to help any air that was trapped get to the rad inlet and outlet (had to tilt it both ways as the two rads face in opposite directions) and in about 15 more minutes another 4% was gone. For about another 2 weeks once in a while I would find a lonely air bubble stuck in the loop somewhere needing a little pinch of the hose to make it to the res. Not a bubble since. If you pump is any decent (and most people would call mine crap :eek: ) with a little help it will push all the air out in short order. What I am saying is dont worry too awfull much about it, its going to cool fine with some air trapped at first and that air will work its way out fairly quickly with just a little help and patience.
What totally freaks me out the most, despite being very good at physics etc. is why when the system is off, all the water does not run down to the bottom res and overflow it.
I understand that there is no difference in air pressure in the loop to allow that to happen, but its still weird as hell to take the top off the res with all that water above it, and nothing happens. So counter-intuitive Magic ! Magic I say!
Bizzare isn't it! I would have thought that too, that with all the water in the radiator, above the water level in the reservoir that it would all flow back down again.... I guess for water to flow out of the radiator, it has to be replaced with air from behind it, and behind the radiator is the outlet to the reservoir.....
Confusing to think about.
Dave
I really dont think it makes a difference in the long run, just having the reservoir above the radiator makes it easier to get the bubbles out of the loop.
Its all abpout surface tension, if you ran a small tube up to the top of your loop and let some air in it would drain really fast. I have a Thermochill PA120.3 on top of my Antec P180 and the t-line at the bottom. When I fill or bleed the system I just undo the small screw on the top radiator and slowly fill the loop. So far I have filled it twice and there is usually only one or two air bubbles in the system when I am done. Although I have the tube for the T-line long enough that it is above the top radiator so I can fill it all the way up :D
Yay for 5 minute bubble removal
Do I have to remind you how many FEET of water normal air pressure supports (instead of inHG think ftH2O)?
I dont understand, I took a glass of water and at the level of my waist, tipped it side ways and all the water ran out , got my feet wet and now I have to mop the floor. As far as I could tell the air did not support any of the water !
J/K :p
Of course you are absolutely right, I had to think about it for a minute, its has nothing to do with a "difference in air pressure" at all As you point out its just the air pressure pushing down on the top of the water in the res that is keeping all that water "up in the air"
Where is that damn mop ?
