Never heard of the company, but looking at their website (http://www.afox-corp.com), they could be SSF's new best friend.
They also make a short single slot 6850.
Yep & that single slot 6850 looks like it just might be short enough for a q07..
You mean the Lian-Li PC-Q07? That case takes full-height cards, so what would be the benefit of using a low-profile card in the Q07?Yep & that single slot 6850 looks like it just might be short enough for a q07..
And this 6850 has a double pci bracket, so it wouldn't fit in the Q07 without some mod.
(Ignore this post if you were talking about a different case)
I don't know if he was talking about a different case, but he's talking about this single-slot 6850, not the low profile one in the OP.
As an aside, apparently Afox is a Foxconn spinoff company, in case anyone was wondering.
That single slot card is still too long. Darn it all.
I didnt even look at the link but figured that it would be too long. The PCQ07 is a tough case to work with. Palit 460 is its best friend.
Would the LP fit in like an ISK 300 or something?
Nope - the ISK 300 only takes a single slot LP card.
You guys know about the Palit GTX 560? At 7.4" it looks like it should fit in the PC-Q07.
Q07 only takes single slot cards. So if you're okay for modding, the Palit GTX 560 is a good card.
From the picture, it looks like a dual slot graphic card. In the specs, (1 slot x 2) very last one.
