Radeon 2600 Pro vs XT - 1080p
Discussion in 'AMD Flavor' started by userjack, Oct 13, 2007.
  1. userjack
    userjack n00b
    43
    Sep 1, 2003
    Can't get any video acceleration from the built in video on intel G33, so I'm looking at PCI-E cards for my HTPC. Radeon 2600 seems the best choice, but can't find any info if there is a difference between the Pro and XT versions. I'd prefer Pro as it works at lower frequency and voltage, but will XT produce better picture?
    TIA
  2. ctark
    ctark [H]Lite
    70
    Apr 26, 2005
    No, the pro is fine. the 2400 will produce the same picture as a 2600
  3. userjack
    userjack n00b
    43
    Sep 1, 2003
    No, it won't. There are numerous reviews online showing far better postprocessing on 2600.
  4. munkle
    munkle [H]ardForum Junkie
    11,188
    Jan 16, 2005
    This is true but I don't think I have ever seen a review with that had both the pro and xt with 1080p. The xt is only $20 more I would get that just in case something is neutered on the pro card.
  5. jmackay
    jmackay 2[H]4U
    3,929
    Nov 23, 2006
