Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Yeah i was trying to find this case to build it out , a guy from the "untangle" forum said he builds his own and sells them loaded with untangle but wouldn't give me the case so either he doesnt really build the system or he found a really good copy of the rackable systems case
If anyone knows where you can find the case above i would greatly appreciate it
Yeah I'm not exactly sure with that one. I haven't seen any server cases that have ALL the connections up front. That would be handy if you don't want to climb in behind the server much though I would say.
