I recently installed a Gigabyte R9 290X in my HTPC (specs in sig.) and am having a puzzling issue.
As soon as any driver is loaded (default windows one, 14.1 beta, etc.) the mouse pointer becomes HUGE. Turning on mouse shadows causes it to go back to regular size, but the pointer in games remains comically large.
This is apparently an old bug from the 5xxx days that has resurfaced. From what I can find (thanks Google), the only way to fix it is to manually edit the EDID info. Is there any other known work around to this issue? Anyone else suffering from this?
I was fairly pumped to try this card out, but I'm quickly souring on the experience. I've already had to use a driver sweeper program to get games to run normally (had been awhile since I had to do that...) and connecting the HTPC directly to the TV instead of the receiver makes no difference.
I've owned 5850 Crossfire and 6950 Crossfire setups in the past, so I understand things may take some tweaking. For a single gpu box connected to a TV that I use an Xbox controller on, I was hoping for stuff to just work.
Prior to installing this card I was running a 560 Ti which had no issues.
