Well, first off I'm new at DIY yourself pc's. If you'll see my sig I have myself a great system. After some tweaking in the bios with off course the great help on this forum, I have it running very stable now. Took me a lot off hours understanding what I was doing with the settings etc.
So now I come to the next part for my rig. The cooling. That cpu in there runs hot. At stock I'm safe but only just. I'm using coretemp because TAT doesn't work for some reason. At full load with Prime running small FFT's on 4 cores, the temp go's just above 80°C after seconds.
I'm changing already the stock fans of the coolermaster with the brand papst + I will add one extra. These are ordered already, and are mainly to get things more quite. That extra is of course for better air-flow.
Now someone pointed out to me that there might be an issue with the placement of the Zalman. I'm trying to find a place where I can find that Masscool Shin-Etsu X23 Thermal Interface Material in Belgium or the Netherlands. Untill now no luck. But this will be the first thing I will attempt to get the cpu cooler. It's the cheapest.
But untill then, I have some time, and this time I want to spend about learning Water Cooling and what I can expect from it.
I was thinking about that Freezone, but following that thread there are also people with very negative results, but no answers why they have negative results. But then again, there are some with very good results also. Extremely good results even.
So now all advice is welkom. There are some things that are important for me.
1. All has to fit inside the case, so no radiators hanging outside.
2. Things have to be quite.
3. The thing has to cool off course, and cool very good!
So is this possible?
