Quiet, cool, strong PSU?
Mercutio
If you want quiet, ditch the Silencer 750. It is not quiet nor silent by any means.
Anyway the Corsair 620HX will be enough for your rig, quiet and it's modular! What's not to love? Just buy it from zipzoomfly.com or buy.com since Corsair PSUs are a bit more expensive on newegg.com
The Corsair HX520 and VX550 will also be enough for that system, for the record. All are excellent PSUs though.
Thanks guys. Are all three of those PSUs standard ATX size? I may be putting them in an HTPC. A large HTPC, but room may be an issue if the PSU is larger than standard dimensions.
I find that interesting also. I have the Silencer 750 in my Rig and I'm using about 375W and my computer is on maybe 14-17 hours a day.
I know Corsairs are also quiet but I say go for the PC Power & Cooling.
The lower-wattage Corsair units are normal-sized. The HX1000 is definitely longer, and I'm not sure about the TX750. You'll be fine with any of the units Danny and I suggested.
The Enermax Modu82+ 625W got some very good reviews (quietest PSU according to silentpcreview!). It's the same as the Pro82+, but with modular cables.
Corsair or Seasonic or PC Power and Cooling's Seasonic based PSU should be fine as they are all pretty quiet and powerful plus they are pretty reliable!
Can't hear either of mine either. I had to put my hand over the exhaust to check that the fan was even running.
