I'm planning on mounting my rad for my wc setup on top my case, and I was wondering would it be easier just to remove everything from my case and then drill the holes or should I drill out the 12 or so rivets in my case and then have to re-rivet it?
Yeah you definately don't want metal flakes on your components. If you take all your stuff out then it shouldn't be too hard to vacuum up everything when you are done. So it just comes down to how difficult it is to take everything out compared to how difficult it is to drill our your rivets and then rerivet. How much stuff do you have in your case?Glyphic said:tools aren't a problem, I work at a hardware store, my only concern about leaving the panel on is stray bits of aluminum
