Quick Questions on Motherboards
erorr404
Are there currently motherboards that support both PCI-E and AGP? If so, are there any high performance ones that have this dual support? And will there be any good motherboards in the future (about 6 months to a year from now) that still support AGP?
The reason I am asking this is because I am planning on buying a new, high-end, AGP video card. I would buy a PCI-E one but my current motherboard (an old SiS 648 chipset one) only supports AGP8X. So when it comes time to upgrade my aging motherboard, I want the new one to still support my AGP video card.
Thanks in advance!
Technically no; however, there are PCI-Express motherboards that have "AGP-compatible" slots. Since the AGP connection was an extended version of the original PCI, many manufacturers have made PCIE boards that have slots which are electrically compatible with AGP and allow you to use and AGP videocard. However, performance of any videocard in such a slot will be worse than even an AGP 1x slot, since the slot is running at PCI speed. (Performance will be worst on games that require a high fill-rate, like Far Cry.)
Searching Newegg, I only found one AMD motherboard with such a slot, a Biostar:
http://www.newegg.com/app/viewProductDesc.asp?description=13-138-249&depa=1
There are a few more boards for Intel chips:
Albatron
http://www.newegg.com/app/ViewProductDesc.asp?description=13-170-123&depa=1
AOpen
http://www.newegg.com/app/ViewProductDesc.asp?description=13-137-054&depa=1
Gigabyte
http://www.newegg.com/app/ViewProductDesc.asp?description=13-128-248&depa=1
wow, that is bad news.
i guess i will not be buying one of those motherboards, if this is indeed true.
how long do you think it will be before its time to upgrade my motheboard and CPU? (SiS648 chipset motherboard with Northwood P4 2.26C)
cause when i upgrade i guess i will have to get a PCI-E, since that will be the new standard, and i can say goodbye to my new 400 dollar AGP video card which will no longer be compatible.
maybe the best solution would be to buy a new motherboard (PCI-E) and CPU, along with a new PCI-E video card (X800XL).
EDIT: btw, will the new chipset Intel motherboards (915/925) support an old northwood 2.26C P4? or do they require the new LGA P4's only. i just dont want to dish out a lot of money right now, so i want to keep whatever i can from my old computer.
Are those (Via's) chipsets true AGP 8X or are they the AGP/PCI thing as described above?
The PT880 Pro appears to have full AGP 8x capability; it looks like they tacked on the PCI-Express portion from their 894-series chipsets. Compare the block diagrams of the PT880 and the PT880 Pro. Also, they've added the ability to choose between DDR or DDR2 on the same board. Looks like an interesting bridge between technologies.
According to this Tech Report article, Abit, Epox, and Gigabye are all preparing motherboards with the PT880 Pro, and they should become available soon. MSI also seems to be preparing a board (link).
Thanks for those links. Now if only it comes with a locked PCI/AGP/PCI-E bus. You never know with Via sometimes :(.
