Quick question
MaxxPhour
I am purchasing my first loop, and I need to pick up a couple things for a T line. I was just wondering if a T line was really the way to go; I have seen Y fittings, and I would think that that would be a flow. Or does it really not matter?
Honestly makes no difference. :)
Eh, I wouldn't go that far. I've seen (physically) some systems with a plethora of 90 degree elbow fittings and T-lines that adversely effect flow rates. In those cases I'd suggest Y-fittings in order to minimize resistance. But for the beginner, Arcygenical is right.....there's not much difference.
-EGA Wrangler
Chemist, Computer Scientist, and Captain of Marines
-EGA Wrangler
I think he meant using the bottom 2 ports as an inline branch for coolant filling...
IE, water wouldn't be directed at the 90 degree angle, but a straight 180 degree angle between the barbs along the X axis, and a column of fluid would rise above the Y axis in almost complete stagnation, terminated by a fillport.
In that case, as water is simply affected by the change in ID, and no added restriction due to a re-direction of water flow... I'd suspect an imeasurable at-best decrease in performance.
IMO, t-line is horrible... Reservoir and drain line is infinitely better...
@Arcygenical -
A-ha! I can't believe you got all that from the first post! Good grab! Anyways, I completely agree with your explanation. I had assumed he was comparing T-lines to Y-branches...
-EGA
