HX is their enthusiast line. It's also modular. The TX series are not.
im replacing my Corsair 620HX and i see that the the 750TX cheaper than 620XH , the problem is the dont have any HX models in the stock at the moment. is it ok to get the the 750TX?
thanks
The HX620 is a slightly bettter-quality PSU than the TX750, but the TX is still a great PSU and will be perfectly suitable for replacing an HX620.im replacing my Corsair 620HX and i see that the the 750TX cheaper than 620XH , the problem is the dont have any HX models in the stock at the moment. is it ok to get the the 750TX?
thanks
thanks
Which means it will run cooler & quieter & probably outlast the usefulness of our current ATX/EPS requirements.Another vote for modular. It's definitely a feature worth prioritizing. I'm considering a new PSU and will only go with the HX1000 even though it's more expensive and powerful than I really need.
Good call! I went ahead and ordered an HX1000.indeed i want stay with the modular, so i got them to order another HX620Wcgoing to pick it up now
Just adding a couple more hard drives. The HX1000 has more horsepower than I really need at the moment, but I decided to keep my desktop PC for at least another two years instead of buying/building a new one this summer. The heftier PSU will easily handle any upgrades (new CPUnice 1000 watts? Man what computer are you building?![]()
